Hi all, I've just bought a 2015 ct200h F-Sport, and I want to upgrade the wheels to 18" or 19".  Does anyone know what offset will look better than the standard wheels?
The standard 17" look terrible IMO as they look like they need 20mm spacers on them!
Thanks for any advice.
19" wheels will need 215/35 r19 tyres if you go for the same width - TBH you'll struggle with the sidewall as itll be 37mm wide - you'll literally clip every single pothole or raised surface with those on and especially when turning.
18" wheels are better - you need 215/40 r18 tyres if going for the same width. Sidewalls will be better but still pretty slim.
Go for ET35 for a flush look on 7J alloys. Itll push it out 10mm on each side.
This is a car with 19" wheels
As you can see, no sidewall whatsoever.
Just to confirm, have you actually driven the vehicle before? Putting 18" and 19" wheels on a CT which already rides overly stiff, even more so if you went for the F-Sport model is a total no no, hence why nobody has really done it.
