Ive got a '03 IS200 Sport and its only my second day driving her but ive got a previously un-noticed noise when I brake.
From pretty much any speed as I slow down and it drops past 25-20mph theres a banging noise from the drivers side front wheel (or that's where it sounds like anyway). Its always at that speed and it does it 9/10 times when slowing down. harsh braking or soft braking makes no difference.
ive replaced both front bottom ball joints and track rod ends and theres no play in the top ball joints.
Anyone with any experience of this or any pointers of where I can look?
Thanks in advance.
Good chance tha one of thet the sliders on the brake caliper is seized, take the caliper off and check if you have uneven wear on the pad, that will confirm if that's your problem.
Another member had similar issues, ended up was the bolt that goes into the slider was loose causing it to move, worth checking over any aspect of you're brakes to rule out the problem
Hopefully il get time to strip the brakes out this weekend, il see what I find and post back if there is anything
Those bolts are a right PITA, curse of my car...
