Power boot beep
Not seen anything about that, but I need it to make sure the boot is reacting to me pressing the key, it can sometimes take a while to do so and the beep confirms it is about to open, albeit slowly.
Its worth checking the owners manual - theres a section which says "Customization" or something along the lines of that.
If it can be done, itll be in there but most likely its a dealer thing only compared to the ones you can do yourself.
Had a quick check of the manual, the only customisation is the height the door opens to.
I think it will be a dealership job myself.
Yes, I tried different heights, but you can't get anything in or out unless it is fully open, so a bit pointless to be honest. :)
Its only really for height restricted garages I reckon.
The beep has saved my son a few times from wacking his head on it - hes at a height half way between the bumper and the top of the car which doesn't help.
I will just have to live with it.  I know there are some car configuration settings that are dealer set only, will check them before the next service.
Thanks anyways.
