Does anyone know whether it's much of a job to replace the raer wing  radio aerial on a 99 ls 400 , in terms of connections/removing trim etc? I'm having a partial respray, doing both sides to freshen the car up and want to replace the aerial, which is tarnished gold colour, with chrome, as well as the badges. Also, does anyone kno where I can get a decent quality replacement
thanks in advance
From what I remember from doing mine it's a case of removing the top nut with a wide blade screwdriver ( mask around the aeriel in case of slips!) then remove the trim in the boot. (Various clips and push fittings).
There is a single 10mm bolt to remove then a multi plug for the electrics and a connection for the actual aerial lead ( pulls out of a socket).
The whole lot should then be free to remove.
Chances are it's just the insert that has failed so less than £20.00 for a replacement on eBay.
There is a tutorial for fitting this on www.lexls.com albeit for the earlier model but very similar.
http://www.lexls.com/tutorials/audio/powerantenna.html
Thanks Steve. I should have mentioned that the aerial is working fine, it is just looking shabby. I've seen the tutorial but it's for an earlier car, I wondered if the mk 4 is the same
Removing the top nut is exactly the same, the boot liner is different as there is no toolbox present on that side on the series IV.
Where it says 2 nuts on the tutorial there is only one on the IV on the boot mounting.
