32 minutes ago, Big Rat said:
David
Is yours still under warranty, I've discussed a few things with Lexus warranty on the phone and apart from exhaust back boxes everything else I mentioned is a no no computer says invalidates 😂
Oh ok, yes i have the Lexus warranty but didn't think it would be an issue . I seem to recall some of the members on hear with custom exhausts have apparently spoken to them in the past, & as long as it was only Cat back, that it wasn't an issue. Hadn't considered that fitting none OEM bushes might be a problem!! It's not like it's a major performance upgrade.
Shouldn't totally void warranty. If a suspension component was to fail as a result of, or linked to the bush, you might have an issue. But they would honour the warranty for the rest of the car.
I agree cat back was ok the list I gave them one of which was suspension mods was a no.
Personally it doesn't bother me after a BMW335i m on run flats an IsF is a magic carpet ride slithering it's way down the road on a cushion of air 😏
Paul & David
Thanks for pointing this out.
I probably won't bother while I have the warranty unless the front tyre wear starts to become an issue!!
