Engine and gearbox
Andy Bass
The rattle at start up is the vvti - a bit concerting when you hear it at first - a few people have experienced it. (Sounds like a machine gun!)
I have had it and cleared it with engine flush and oil changes.- it will go over time if you regularly service the car.
I cant comment on the gear box as I have an auto but I don't think that's a common issue - someone will come along with a manual and explain the noise I am sure
I had a manual 2 years and found no problems with it, change the gear box oil anyway for starters, has the car a decent service record? if not you better get a good mechanic local to you.
102k miles is high milage, i wont ask how much you got it for but i would gather on the cheap side, you need to realise these cars are expensive to maintain and upkeep.
Did you not notice the gearbox crunching when test driving ? Would try changing he gearbox oil first see if it makes any difference if not could be a problem with the syncros, from experience if it crunching quite badly in a few gears you might be wasting you're money changing the oil.. Hope you get it sorted
