Does this look like normal wheel camber on the IS?
Both look the same on full lock, straight on they look normal and the car drives OK (it does pull very slightly left)
Looks fine to me.
Id be inclined to check the toe in/toe out instead of the camber. I believe the camber is non adjustable anyway.
Looks perfectly normal to me. All cars do it - due to king pin inclination - not that it has king pins, but the steering axes slope outwards from top to bottom and the steering knuckle is effectively a wedge shape (wider at the top, narrower at the bottom) so when you turn from straight ahead the camber changes substantially. You measure camber with wheels in straight ahead position.
Thanks Rayaan / John, nice to have some reassurance :)
