The flasher key? Little red triangle thingy....
How do I get the flasher key off to replace the bulb?   Thanks in advance....:rolleyes:
Btw  Guildford Lexus have kindly agreed to let me play with a shiny new RX 450h for 24 hours
this Thursday. When I open the glove box I know there will be an order form laying there......:yahoo:
Do you mean the hazard switch next to the clock? If yes you need to take out the stereo which then gets you access. You start by pulling the trim off around the gear selector. Have a look at this video, easier than trying to explain in words.
It is quite easy, just be careful when removing the stereo as the metal brackets are sharp and will scratch your trim.
