I've upgraded the firmware on my Premium Nav unit this week:
Old version: VD12102F
New version: VD12103A
According to the release documents, it is mostly bug-fixes but the main one for me was it fixes an issue with the split-screen nav mode where the turn-by-turn icons are displayed empty.
Did you have a Yellow Fiat Coupe Phil?
I did it myself but it isn't available on the portal.  You need to get the files from https://www.lexus-tech.eu
Do a search for ECU Software updates (even though this isn't for the ECU) and enter your VIN number.  It will ask for the technical services bulletin number which is BE-0081L-1113
How do you update it again, just download it to a USB and then?...........
Also does the USB have to empty of other content?
Blank USB.
Unzip download - copy the files HASHLIST.DAT and LOADING.KWI to USB (don't create any folders - USB should only have these two files on)
Enter service mode (hold Menu and switch lights on/off 3 times)
Select Service Information
Select Program Update
Insert USB and the OK button should light up.
Please be careful in the service mode - don't play around with things  unless you are sure with what they do
Thanks for this I am tempted myself for a little update, but my VIN shows 2 files
VC03101G    Multimedia    Update of version F    BE-0081L-1113
VD12103A    Multimedia    Replacement for all previous EMVN software    BE-0081L-1113
Will try and see what is what?
VD12103A is the most recent version.
Not sure why the other is displayed (it did for me too) as it is quite old now.
Thanks, updated fine.  I was already on VD12102C so the other was indeed far too old.  Will see if I notice any difference.
I updated mine today too. Also was shown both the old and new versions same as Blistering Blue.
Couple of tips for others, USB stick needs to be formatted as FAT32. You need to register with the Lexus EU service portal,  but the download is free. Can't see any differences so far, seems faster to navigate yet again. Care to share the change document?
I'm a bit of a technodumbo and this all looks horribly complicated and fraught with mistake possibilities.  Is it not the sort of thing that Lexus do (for free) as a matter of course during a service or perhaps by specific appointment?
I wish they did, but, in my experience, they don't.
They will if you say your system has been hanging/crashing as they will perform the upgrade under warranty. Once your warranty is expired they may charge you labour for performing the upgrade.
I upgraded to the latest version last weekend and its been all pretty good so far.
The display of junctions on the F-Sport colour display is better, they seem clearer and the distance counts down now, they also seem more consistent in appearing, but then how would I know !?! Motorway junctions still don't appear, not sure if they are meant to.  The distance countdown is also out of sync between the main display and the instrument one - it lags behind.
Main improvement is another increase in speed of response and general snappiness, it keeps getting better, with less noticeable pauses. Routing is still a bit hit and miss, it definitely prefers motorway/main roads and road where there are no traffic info for, it assumes must be quicker.  For those who haven't upgraded yet, I'd say no reason not to.
Hi, I too upgraded the firmware to VD12103A for my premium sat nav on IS300h SE. This as resolved a long standing problem and that is the favourites in my telephone address book now stay their, previously I lost them as soon as I turned off ignition which was very annoying.
Just done update, interface is now much quicker. Should have been like this from the start, but good to see it now sorted.
Still haven't got around to this. Once update is complete do you have to get out of service mode? And if so how do you?
On 12/06/2016 at 6:49 AM, Steve44 said:
Just turn the car off and on again.
Ah simple enough. Ill give it a go - hopefully wont screw anything up
Hi Rayaan, is it likely that you will post your findings when you have done the update please.  I am toying with the idea of doing mine very soon and it will be interesting to see how easy or tricky the job might be.  Many thanks.
Yep I can do - Ive just realised that I dont have any USB sticks! Oh my days how the "cloud" has changed us!!
Ive ordered one, should come in a few days and ill have a go to see what happens.
just tried the update and no issues after update applied
will have to see what its like in the morning.
