Hello all
new to the forum after purchasing an is220d the car runs great and looks perfect the only thing that needs doing is the grille and wheels.
1. Grille, ive seen tutorials on here about changing the stock to the ISf mesh.
i was wondering where I can pick up the part, I've checked eBay and other sites and I can't find it in the Lexus catalogue, just need a little help locating one that's reasonably priced.
2. Wheels, can I fit 18" on without any issues? I'm completely new to changing stock wheels to aftermarket also can anyone point me in the right direction to look for said wheels as well?
Kind regards
kch
oh also it's a 2007 lexus
26 minutes ago, Kch said:
Hello all
Kind regards
kch
Both wheels and mesh is pretty straight forward.
Mesh you are referring to is "F-Sport" mesh, not "ISF". That said you need to get aftermarket one matching your car manufacturing year... I believe it is slight difference between "pre-facelift" and "post-facelift" models... That would not be huge difference, but it is easier when all the holes are fitting straight away right?
As for rims - if you get Lexus OEM 18" they would be direct fit, this is not even a upgrade or modification, but rather retrofiring factory option (don't forget 18" was an option on both IS220d and 250).  If you get aftermarket ones - it would be better to stick with OE dimensions (18x8J Front, 18x8,5J Rear - can someone confirm ET?). That said even slightly different rims would fit fine (unless you go to something mad), but you might have issues with alignment etc.
The standard setup is a staggered one, 255/40R18 on the rear, 225/40R18 on the front
I think this means you need 18x8 rims for the front and 18x9 rims for the rear
PCD is 115.43x5 and I believe the offset is ET45
Thanks so much for the advice guys
I've ordered a fsport mesh from eBay (2007 model) as for the wheels can anyone recommend a site? I don't want anything too OTT just something that looks clean.
On 5/18/2016 at 0:02 AM, Kch said:
Nice style, thought I don't see 18x8 as an option. That said 8.5 are no good on front - you would be better of with all 18x8 (rear being narrower than original), than with 8.5 on front (which will be too wide). In other had if you stick with standard tires it would make front to be slightly stretched.
That said it probably won't rub archesin fron, but will look little bit weird. Cannot advise on ET (it is a bit of mysterious setting for myself).
That link points to a set of wheels with a 112mm stud pattern. if you change this to the correct 114.3 pattern for lexus then only 9.5r/et18 size is available.
Wheelbase offer mixed size sets, this a set of 18inch mixed 8J/9J with a similar design to your link
http://www.wheelbasealloys.com/alloy-wheels/ava/phoenix/hyper-silver/18-inch-wider-rear
I think the 9J's will take from 235 to 265 tyre width so they will be OK with either the standard fitments or you could even go for fatter 265 rear tyres.
I note that the rears have a smaller offset than the rears which I assume is to compensate for the wider rear rims?? Might be worth giving them a call to confirm.
Thank you for the advice
Looking forward to getting them
Which set did you go for?
Remember to post some pictures :)
This is the look of the grill I modded after finding the mesh on eBay - came from the USA - the grill mesh matches the lower bumper mesh
The eBay listing number for the one I used below is 360916182862
 I am really wanting a dark colour unfortunately the ones you,       suggested from wheelbase only come in silver but I found this set below , which come with the right widths front and rear for the is220d just need confirmation before I order can anyone confirm this
http://projexuk.com/wheels/3sdm/0_01/mattblack
i have called and they said they would fit...
As far as I can see - widths available are 8.5 and 9.5 which are respectively 0.5 and 1 inch wider than stock.
If you asking if they fit - yes they will. They will accept the stock tires as well with noticeable stretch (will look more similar like ones on Golf5 from your link). And probably will not rub arches as well. However, they will not be as stocks are.
If wider/stretched looks is what you after, then it is fine... otherwise look for 8 and 8.5 respectively for front and rear.
I need a new set of shoes anyway so I might just buy the alloys and respective tyres to avoid the stretch
the company is located 30 mins from me so they kindly offered to put a set on and see if I like them going up Tuesday next week
as for for the grill I have ordered one from the U.S. And it's on the way
with the wheels on Tuesday the car is coming along nicely
i will post pics when it's all together
I might be worried more about that, then a stretch. Stretched ones won't rub and wider ones without stretch might (not saying they will, but it is more risky.. then getting right width alloys at the firs place).
I really like look though, sadly they don't do "gun metal" option.
So can one change 255 40 R to 265 40 R in the rears stock 18inch? Will the upgrade be visual? Or is 10mm minor change and one won't notice ?
What disadvantage will it have ? ?
I believe the stock rims are 18x8.5 at the rear - so a 255/40R is the maximum you can fit.
