Has anyone or is it even possible / legal to have the sidelights / parking lights sorted to be equivalent of DRL?
I'm thinking the LED bulb swap, and wired somehow to come on with ignition.
surely I can't be the only one that's thought about it, which suggests my Google-Fu isn't very good, or I'd have found the answer one way or another.
There are conversion kits available on eBay.com which I think are oem, but there aren't cheap, plus postage from the US. Other cheap replicas available but wouldn't trust those. Recently there was a 2008 on AT with the DRL conversion, so yes it must be possible....but.... it has been debated on here that owners have generally preferred the adaptive headlights. I have considered it like you but currently not wanting to spend £1200+ on that aesthetic mod.
Fair enough.
Is the DRL conversion to the sidelights though? I'll have to look at the details.
That not withstanding, no danger of me spending £1200 on that sort of mod.
Do you have the light sensor for Automatic headlights when it gets dark? If you do see
