Anyone help with this one - I am after part numbers for the oil drain plug washer (the fibre washer) and also the oil drain and fill washer for the diff for a 2007 is250
Two attempts at Lexus - they don't know and cant supply the parts without the part numbers(or wont supply?!) .... crazy, as they don't recognise what I am asking for - I know they deal with a lot of parts but come on....
Or even better - anyone know where I can buy these from - either OE or non OE parts
thanks
http://www.ebay.co.uk/itm/140-Pieces-Washers-Solid-Copper-Sump-Plug-Assorted-Garage-Engine-Washer-Set-/281732290574?hash=item41988d980e:g:bbcAAOSwLVZVjDpJ
http://www.ebay.co.uk/itm/Fibre-Washer-set-600-Assorted-Fibre-Seals-various-sizes-Sealing-Washers-/161652064615?hash=item25a336c167:g:IPoAAOSw-7RVE867
I have used these on my vehicles for years , Boxes have lasted for years and inexpensive. Not used on my Lexus yet, I do intend to though shortly re oil changes,  but worth a look as long as there is nothing special about the sealing washers for your vehicle ?
Thanks Ian - I looked at these sets as it makes sense. I wasn't sure on the size and whether the kit covered it so was looking for the exact OE washer. I found an old washer in my garage tonight and measured it at 21mm outer diameter x 12mm inner diameter - its a fibre washer. The link to the £6.99 fibre washer kit has a 40 of these - will be ordering this kit. I have always used the fibre washers.
I am going to change the diff oil also so may take a chance on the kit having the correct sized washer in it. I cannot find any of these on the web. Once I have changed it I will know the size.
Hope it works for you as the Copper or fibre kits have a good size range and with all my past vehicles it always seems to work out ok .
