Hi
Im  a new boy to Lexus ownership and to this site, I was hoping that some of you guys could please point me in the right direction to a cure for a small problem I have with the car
The car is a 2006 GS300 and the moon roof is dead ie when you press any button for the roof nothing happens, question where are the fuses for the roof ?,I understand there are more than one but the owners manual seems very vague about them
So, fuse numbers and location would be helpful, also any hints on the problem if not fuse, ie how do you remove the overhead light unit to access the motor?
If this subject has already been covered on the forum I apologise and can you direct me to it
Cheers Ken
Hi Ken and welcome to the LOC, we are a friendly bunch and some of us even know how to pull them to bits and put them back together again, with of course the one bolt and washer left over.
I cant help with your present queries but I'm sure someone will be along ASAP.
We recommend you spend a couple of mins looking over the rules of the LOC, we will be asking questions later
http://www.lexusownersclub.co.uk/terms-conditions/
Regards Mike.
Hi Mike
Thanks for the welcome, hopefully as you say someone will know the answer.
As suggested I have read the rules and as for any questions .....I wil only give name,rank and serial number !!!
Regards
Ken
Hi
Just thought I would add a quick update on my problem, after lot of detective work found the fuse, checked OK. Decided to check the motor, found it disconnected  and the drive for the roof all chewed up. Had a look at cost of replacement.....Ouch!......looks like the roof will be out of action for some time.
Ken
3 hours ago, kiloken said:
Hi
Ken
At least (hopefully) it's dead in the closed position!
