Hi Geoff and welcome. Do you mean what other oem Lexus springs or aftermarket ones? The Sport has 15mm lower springs than the other models but the shocks are the same. If you want to go aftermarket, then I used Eibachs on mine which were great, before I went full coil overs. Have a look on eBay there are loads of oem and aftermarket springs on there.
Have a look on eBay
Tein
Apex
H&R
Eibach
Only problem with Tein is there is less of a drop. The rest have 35mm drops which makes the car feel a bit tighter in corners and looks lower but not too low if comfort is your thing then 35mm drop will be perfect. I'm using 35mm Apex
