On My mk3 :mellow:
Radio 1,2 and dome fuses changed,all others in both locations checked.
Amp and head units changed for known good units.
No lexus phone fitted,checked cradle plugs under centre console
Phone ecu/speaker relay plugs connected in the boot (tried un plugged as well) but was all fine plugged together since ive owned the car.
I have run out of ideas now,and its very frustrating as when working it sounds great.
Hope someone can shed some light on the subject.
My old Mk3  stereo used to cut out going over bumps in cold weather, really!, If I recall correctly, there was some mention of it being down to the stereo mute control, and a bad connection under the back seat
Thanks Ian,i have checked under the rear seat lower cushion,no problems found.
Would anyone have a stereo wiring diagram for the 95 with pioneer head unit ?
Thanks Q, i will trace the mute wiring in the car once i get a minute
