Hi guys,
Winter is over and have given the girl a good going over, when it came to the wheels though nothing I have (dont have any proper alloy cleaner at the moment) sorted the wheels to a standard that I liked. Can anyone recommend a good cleaner please? I am loathed to use an acid based one like Blitz although it gets good reviews as i'm not aure about the plastic birts in the wheels and they look a little marked as it is. Bought some brushes so I can get in there but just cane seem to get all the marks off.
Have an 08 450h.
Wayne
What have you used so far?
Use something like Valetpro Bilberry - maintenance washes should be at 1:5 and if they are seriously bad just use it neat. If that doesn't shift it, the only thing you can do is use an acid based one like Wonder wheels! Once is OK but don't make it a regular habit as it can corrode wheels if used too much.
I have used Wonder Wheels in the past but not on the Lex as its had refurbed wheels on - I think its acid based but works real well
Really only shampoo and a little bit of a wax with a little cut in it, as I said I dont have anything wheel specific, havent tried anything like fairy liquid as didnt think that would do any good.
OK, well yes, something like Autosmart Smart wheels if you can get hold of it - use it at 1:10 dilution with water first and for maintenance washes, if that doesn't shift, use it at 1:3. Dont use this stuff neat unless you really have to, very concentrated. You should be able to find it on eBay.
Yes its acidic. Dont go using that on kerbed wheels or wheels with pinholes in it. It'll bubble the paint off.
12 minutes ago, piasek said:
Bilt hamber
Bit overpriced - the only thing it does that Autosmart smart wheels can't is bleed purple and remove iron fallout - much cheaper options out there if you want to remove fallout.
I wash my car frequently.....don't need anything special on the wheels, just normal shampoo.
It helps if you wax the wheels too when you polish the bodywork.
Actually that's a good point. You'll only need the wheel cleaner for cleaning wheels before using a wheel sealant on them. Then just use car shampoo
Don't use wheel cleaner on sealed wheels as it'll strip the sealant
Wonder wheels do a non acidic wheel cleaner which I use and like some of the other cleaners here it turns the brake dust purple/red.
its quite slippery when on so makes it easy to clean the dirt off.
your local Halfords sell it to.
carl
