On the IS200 exhaust, there is a lambda sensor on the centre pipe, after the main cat section.
I have just received my new catback system (designed for IS300), but there is no hole to put the sensor in :geek: Isn't the sensor at the same place on the IS300 or is it a mistake of the pipe maker ?
The dimensions and fixations are right but I have nowhere to put the lambda sensor. I think I must put it back on to have the car runing correctly :unsure:
Yes the lambda should be fitted back on the same position, because the ECU reads data from "Before CAT" and "After CAT" to calculate correct values for A/F mixture.
Don't know about the IS300, try to get some info about the IS300 exhaust, but as far as I know the IS300 and IS200 exhaust pipes are similar, except the header of course.
Maybe it was a fault by the exhaust shop.
If you could do it by yourself.... drill a hole and fit the sensor.
Or cut out the little thing from the stock exhaust pipe and weld it into the new pipe.
Just a suggestion,
RR
I'm going to drill a hole and weld the sensor.
I aswell thought the Altezza, IS300 and IS200 have the same catback exhaust, only the header /main cat sections are different. :unsure:
the is200 has the sensor after the cat, the is300 doesnt.
i dont recomend welding the sensor in :blink:
get a new sensor lug to weld on the pipe, any exhaust manufacturer should be able to supply you one
Thanks for the info on the IS300 Mat, that's what I was looking for B)
Don't worry, I have an other sensor on order :) It is the sensor lug I will weld
