IS200t is born
Picked her up yesterday. Well pleased with it, looks the business. Cant believe how well she handles and goes like a scalded cat. Getting around 24 to the gallon so far but to be fair have been thraping it quite a bit, seats are uber comfy for me. Only things I need to play with a bit more are, the satnav, when entering postcode it only takes first 5 digits then have to enter the street? cant find anything in settings to allow me to enter full postcode. Also the radio, there's not a lot of staions available? done the re-search stations a couple of times but still no joy. Other than that a stunning car
1 hour ago, andywin said:
I got the standard, no premium option on the sport.
All modern Lexus vehicles support 7 digit postcode entry.
For example if you have 7 digit postcode such as BD12 3FU, put it into the Sat Nav like BD123FU i.e continuously.
For a 6 digit postcode like BD3 3FU, you have to put it in like BD3space3FU. Try it, I bet that was the problem!!
2 minutes ago, andywin said:
Nah, regardless of space or no space it changes screen after inputting 5 digits to enter the street info. If you go back you have to start again
Ok so to confirm.... you are pressing nav - destination - page 2 - postcode and then putting the post code in?
im not at car now but from memory. Pressed map, destination, address, went right on the menu wheel to the options (the three dots) select postcode. Then the wheel comes on screen for entering characters, select the characters (it was a seven digit but tried a six after as well with the space) it changes screen after 4 characters and allows you to scroll through the numbers for the 5th character, then it changes screen to enter street and house number?
Got you mate!
Ok next time, instead of going nav > destination > address, go to nav > destination > now look for something near the top that says 1/2 and click it to go on 2nd page > then click postcode.
You should get full 7 digit postcode providing you input the format correctly depending on if it's 6 or 7 digits.
I very rarely use the "address" button
Thanks Ray, found it. There's not a second page, its just further along the menu god knows how I missed it, i was going into address and using postcode from there which restricts the characters, further along the destination menu there's a postcode tab as you quite rightly said, this allows full entry. My problem was the car was supplied with a note from the factory to say they havent got any satnav manuals in stock!
