There are some areas through the app that cause it to crash every time, are there plans to update the forum to work correctly through tapatalk. As an example, if I view a user profile from a post, it shows none of the info, and then crashes out a few seconds later.
Normally I wouldn't mind, but as the app had to be purchased, seems a bit odd that things are not kept working.
Incidentally, for a short while, the app wasn't available anymore in the apple Store (I deleted the app to see if it would cure the crashing, but hen couldn't find it again in the apple Store to re-install). At that point, LOC showed up in the normal tapatalk network. Now the app is back, it has disappeared from the network again (everything worked through tapatalk itself though, no crashing)
