AS Above looking at some wheels.
Front 18 x 8 with a 2.125 lip ...................................  Rears 18 x 9 with a 3.25 lip both are F& R et 35.
What issues would i have standard suspension, what tyre size to fill the arches properly.
been looking at wheels myself. I'm no expert at all but from I have read I think the standard offset is et45 so the new tyres, assuming the same size, would sit 10mm further out. Don't know if that is a big deal but I've also read that you shouldn't mess with the geometry unless you have good reason to
It'll put slightly extra load on the wheel bearings. Not too much of an issue as they're fairly easy to replace if they wear out quicker. The car should feel more stable and grip better as a result of the wheels sticking out further.
