Hi I'm  towing my newer , bigger caravan down to Devon this Friday and I think I read on here that an alternative  gearbox oil would be advisable. Any thoughts or advice would be much appreciated....preferably  before Friday.  Thanks.
As far as I know the only recommended transmission fluid is Toyota Type IV for the Aisin boxes, think yours is the A650E model.
I would confirm the above by looking in your owner's handbook.
Perhaps an external cooler would be worth considering.
Mark , the fluid in your gearbox should always be Toyota Type IV or equivalent,( i.e. Mobil 3309/Comma 3309) whether towing or not. Extra cooling is what might be needed in your case. A radiator with a slightly larger oil cooler is available but might be hard to track down.
I thought I was right with the Type IV but on the US club Toyota WS fluid was mentioned?
Thanks for clearing that up guys. So this looks a little more complicated than I first thought. Obviously I won't be able to get it sorted before I go so I suppose it's  something to consider when we get back as we will continue to tour with it.
Steve, as far as I can tell the general consensus seems to be that older Toyota/Lexus autoboxes should not be filled with the newer Toyota WS fluid if already using Toyota type IV. The viscosity and friction modifiers are quite different apparently.
