I've just put the Battery on my LS 400 and check vsc light has come on anyone know how to reset. I've also flooded it moving it. Got  a buyer coming in half an hour. Help
John, disconnecting the Battery can cause the VSC light to come on. Once you drive a few miles it will go out. Don't forget, if your car is a 2000 Mk4 LS you need to leave the ignition key switched in the 'on' position (one notch before 'start') for 6 minutes or the car won't start. DON'T press the accelerator either. Hope this helps.
