Hi everyone I have a few questions as I am new to all this, I've recently bought a v reg is 200 i have put it through its m.o.t, and was told that all 4discs are warped which I would like to get sorted where and what is best? To get these fixed. And also I have a light on my dash which displays the handbrake is on which it is not I was told it was the centre rear bulb has gone or come loose, I have found out that bank sensor 2 is also playing up with sometimes the engine light will be on and others it will not. If any of guys could give me some sence of direction in how and what I need and cost of getting these fixed.       Many thanks in advance mike
Hi Mike and welcome to the LOC, we are a friendly bunch and some of us even know how to pull them to bits and put them back together again, with of course the one bolt and washer left over.
I cant help with your present queries but I'm sure someone will be along ASAP.
We recommend you spend a couple of mins looking over the rules of the LOC, we will be asking questions later
http://www.lexusownersclub.co.uk/terms-conditions/
Regards Mike.
Hello and welcome to the LOC.
For non OEM parts have a look on eBay, Bembo discs are well rated. Lexus Birmingham often have listings for spares on there so check it out.
For the brake warning light check all your brake lights are working and the brake fluid level is up to the max mark.
O2 sensors are also available on eBay but Denso or NGK are recommended.
Hi everyone, I will look into that now and thanks for the recommendations thank you both
