Hello,
Does anyone know if there is a safe/viable LED alternative to the existing, rather dim, interior boot lights for an RX300/350?
I've tried searching for something that could replace a boot bulb ( 12V 5W festoon/dome bulb 28mm )
but with no luck...
Piers
:geek:
Seems mine would be a 28mm, which I cannot find... as an LED.
I looke at the boot light in my 400h and the 31mm will probably fit with a bit of bending of the connectors, there is lots of room!
IIRC when I fitted to my IS250, I had to prise apart the connectors a little to get the lamp to fit.  It's only 3mm!!
Mine seems to affect the little on/off switch at 31mm, so 28mm it has to be ... for me.
On 12/01/2016 at 10:07 AM, steveledzep said:
Just got these and with a bit of bending of the connectors only on the boot light, I fitted them to all three interior lights. They are polarity sensitive so if put in the wrong way don't work but hey you just have to swap them round.
THANKS  Steveledzep ,I have been looking for a replacement for the ' candle ' in the boot of my recently aquired IS  250C  .Very poor on a high end quality car considering all the other lights fitted on the SEL .Ordered
Dave
In the end I found these... on eBay ... "All Ride Superbright 4 LED Festoon 10 x 28mm – Twin Pack – White"
