Any recommendations.
Had a browse on the US sight and it appears Philips 127996000KX2 seems good choice but amazon UK says Osram LEDriving LED Retrofit W5W fits the IS300h?
Anyone had the above ones installed?
Regards.
I took a punt on some from eBay......cheap as chips !
They're bright and white. Work well.
You have not bought chips lately Steve...........they`ve risen from a tanner to over one pound!!
Regards
John
i have mixed a w5w type bulb fitting with a 12 or 16 LED panel
unsolder the 2 end caps of the festoon LED panel
solder 2 wires to the points where the festoon caps where soldered to
strip & thread the other end of the wires through the plastic
w5w cap and fold around the end of the cap.
i have done this for the following locations
interior roof & map lights,door lights,foot lights & boot light
dont be concerned about the power they take as it is minimal
a standard w5w takes 0.416 Amps against a 16 LED panel taking 0.12 Amps
Be very careful with the quality, I bought some cheap Chinese eBay ones that went short circuit and took out my integration relay.
Are they not just plug n play?
Sent from my iPhone using Tapatalk
"they are just plug and play" but i wanted to have more light
the replacement w5w come in different styles some have 4smd's around the side
and 1smd at the end with these i found you have light shinning to the sides and is wasted
i changed it to have all the light facing towards you
i.e. in the boot you have a large area to illuminate and 1 little bulb just doesn't cut it
before i fit any LED bulb to the car i always test them on a 12v supply off the car to make sure they are working properly
and leave them for a few minutes so they warm up,if there is an issue i will find it before there are fitted.
How do you take the light fitting out to fit the bulbs for front and rear roof lights?
small electrical screwdriver and gently lever the lens from the housing.
