hi new to forum
please help lol
my lexus is220d Battery was flat so as norm took out Battery and recharged
upon installing my Battery i now have a dead instrument cluster no sppedo fuel gauge or rev counter
although the cluster still light up to show my light are on
any ideas guys
is there a fuse or fuse block that is connected to the cluster if so where is it in fuse box or is it a more serious fault
Hi Dave and welcome to the LOC, we are a
friendly bunch and some of us even know how to pull them to bits and
put them back together again, with of course the one bolt and washer
left over.
We recommend you spend a couple of mins
looking over the rules of the LOC, we will be asking questions later
I cant help with your present queries
but I'm sure someone will be along ASAP.
http://www.lexusownersclub.co.uk/terms-conditions/
Regards Mike.
Even u charge battery could b still dead check battery rating by using a meter does it start????
thanks for reply
yes the car starts but no life in cluster apart from showing me when my headlights are on
Check relays /fuses should tell u in handbook where relay/ fuse is located hope this helps
It's all controlled by sensor no speedo cable get codes then I'm sure someone will know what the codes are rather guessing and spending money
thanks guys
i get codes read and take it from there
thanks to all who took time to reply
