I've just fitted a set of HID's from http://www.hids4u.co.uk/
More expensive than eBay, but they came with everything needed to fit (took about 15 minutes) without needing to modify anything. It will take about 2 minutes to put the original bulbs back in for the MOT. They also have a 'shield' on the bulb to reduce the glare for oncoming drivers, which I believe they've patented so you can't get similar on eBay.
The light is much better than the original halogens, although the beam is not very 'clean' - there are a few brighter patches. Probably what you would expect from HIDs in reflector lenses. Not too bothered though, because I can see more than I could before!
Not had a single flash from an oncoming vehicle since fitting (mid December) so I'm very pleased.
They didn't have the 55w kit available when I ordered, but they have got them on pre-order. I'm tempted to upgrade for even more light...
