Hello all
I've had a seatch but can't seem to find a suitable bulb or set to replace the reversing lights on my 2011 CT200h. I want to improve the rear visibility via the reversing camera at night, so is that the number plate bulbs or the "actual" reversing lights? Does anyone have some nice and easy replacement options?
Thanks in advance
Mark
Hi Mark,
Think in the settings menu you can brighten up the Camera, might be worth a try first.
i have tried LED bulbs for the reversing lights in another car and they weren't good
the bulb was std indicator bulb p21w and i replaced it for a 68smd LED bulb
the reverse light looked good illuminated nice and bright and white
but it didn't project the light far enough back so i reverted back to the std bulb.
Thanks, I didn't know that! I have a 61 plate, any idea which menu I need to be looking at?
Mark
i have tried led bulbs for the reversing lights in another car and they weren't good
the bulb was std indicator bulb p21w and i replaced it for a 68smd led bulb
Thanks, that's worth knowing. I'll hopefully be able to adjust the camera as above.
