Mk1 Gs300 Windows
jweaseyp
Normal proceedure is to press and hold the down button and continue to hold down for a few seconds after the window has fully opened the repeat with the up button holding again for a few seconds after it has fully closed.
You may also hear a beep.
Repeat for each window.
Some of the ealier generation Lexus models didn't need windows resetting after a Battery disconnect.
If you don't have the owner's manual and you have the 1st generation model I have a spare going for the cost of the postage.
Hiya Steve cheers pal that sounds like it makes sense I'm taking it I do this with the driver controls I will try this tomorrow and I could be interested where are you from and could I do it through PayPal? I don't have the Manuel but I do have the genuine toyota tool kit if I remember correctly 👍
