Any opinion would be welcome ...
For a while now - and I suspect others do too sometimes - my RX makes a rumble sound, from the front?
I hear it when driving at slower speeds,straight, e.g., at 20 mph, but the road does not have to be particularly bumpy.
I suspect, based on reading and research, that it could be shock/top mount, related?
I am wondering... should I take it to my trusted independent garage, or should I take it to my equally trusted, local Lexus dealer.
It was bought from Lexus up North, about 9 months ago, and is still in its first year of Lexus warranty. So I'd rather keeps the costs down if possible...
Does anyone have a view?
:geek:
Why pay an independent garage if the vehicle is under a Lexus warranty, if Lexus diagnose and then say "wear and tear,not covered" then go back to plan B.
I hear a similar sound sometimes on mine but it hasn't caused me any concern and it only happens occasionally at between 5-10mph, usually when accelerating from standstill.
I also have a similar sound but other than lower ball joint and antirollbar bushes on driver's front suspension, everything else has been changed/checked by me a month or so ago (I have new ARB bushes to fit still).
I did notice that my noise coincides with light throttle applied and is most noticeable when the driver's window is open - I'm now beginning to suspect it is an exhaust heat shield that rattles at a fairly specific low rpm... So may not be suspension related at all!!
To clarify it sounds more like a rumble or muffled rattle than a metallic rattle and on mine as soon as you brake/take foot off accelerator, it stops instantly...
Told it's a front OS shock.
To be changed under warranty this week.
:geek: + :hohoho:
All done.
Fixed.
Happy New Year!
:driving:
