Multi Function Display - Not F-Sport
OK, before I start, I have R'dTFM!
On the MFD, on the screen which gives the mpg, and just to the right of the blue instant readout of mpg, there is a vertical grey bar, with a bit of it highlighted. What does it indicate, please? Can't find it in the manual.
Thanks in advance.
It's like the scroll bar on a computer screen, indicating there is more below the current info displayed on the screen. If you use the down arrow button on the dial on the right hand side of the steering wheel the screen will scroll down. The highlighted grey bit shows you are at the top of screen and this will move down as you press the down and then up arrow key. I hope that makes sense!
Sent from my iPad using Tapatalk
It makes every sense, thanks! So, IIRC, if I use the down arrow key, the next screen is blank, the next is the Eco/energy flowchart, then blank, then back to mpg. I must admit, I've not noticed the highlighted bit moving with the page change. I'll check tomorrow.
Another discovery!!
You should be able to configure what is displayed in order as you scroll down. If the car is stationary, go to the settings, then you can choose which of the various mpg, trip meter, energy meters you want to see.
