Sat Nav Control Unit For 2001 Rx300
In theory it should work as you already have the screen and unusually for a Toyota the additional wiring seems to be in place in the boot. Not aware of anybody doing this so cannot confirm it will definitely work. You would also need the GPS antenna.
If the IS200 mk 1 is anything to go by then don't waste your time and money,would suggest you do your homework first as its not just going to be a case of plug and play
It's nothing like the IS, that doesn't have a screen or wiring in place.
