Can anyone please give me any info/advice regarding in-car wifi hotspot from a Lexus dealer,as I'm considering having one fitted so if someone has one already or have any info about them (pros/cons) I'd be most grateful,many thanks.
Hi Raymond and welcome to the LOC, we are a
friendly bunch and some of us even know how to pull them to bits and
put them back together again, with of course the one bolt and washer
left over.
We recommend you spend a couple of mins
looking over the rules of the LOC, we will be asking questions later
I cant help with your present queries
but I'm sure someone will be along ASAP.
http://www.lexusownersclub.co.uk/terms-conditions/
Regards Mike.
In my GS I have Lexus WiFi Hotspot, and it works fine: the connection procedure is easy and it's studied to receive signal better than using a direct connection on cell phone, having a diversity antenna connected. It can connect 5 wi-fi devices at the same time, and of course it needs a SIM with a valid registration. About various settings it works like a home modem router, entering setup trought a cell phone or a laptop with usual 192.168.1.1 address. It can receive updates from Lexus (probably to adapt to newer protocols, 4G/LTE?).
If you wish to know more you can download for free the manual in pdf format from Lexus portal, if you don't find ask me, I have a copy in my documents.
Hi Luigi, Thanks for the info about wifi hotspot, it's helpful thank you.
Could you please let me have a PDFs copy of from Lexus portal thank you.
Kind regards
Ray
  • 5 weeks later...
I don't know if you have already purchased a Lexus in car wifi system yet, but I purchased my own from O2 and it works fine in my car allowing four others to use it. 5GB £14/mth.
