Does anyone know if they are the same?
I can find the 350's ( but not the 300? )
( The ones that Lexus have to change )
Is this from the Sat Nav console or by using Techstream for the C-BEST settings, Piers?
C-Best I assume, Chris?
C-best does things such as enable / disable Window & Sunroof opening by using the remote key etc.
It would cost about £20 to get the cable required for you to do this yourself (would work for both your RX's) assuming you have a Windows laptop...
Your Lexus dealer may tweak a setting for you when you have work done or if they are feeling generous!
As for all the settings, these were supplied on a checklist sheet that a customer got with their new car.
They completed the sheet and a Lexus tech would enter the settings.
I'll see if I can find an example of one somewhere for you!
Thank you!
