K&n Air Filters
200h
no extra power, the stock filter isn't restrictive. You may get a little bit more induction noise, which some people like, and you can potentially save some money over the long term by washing and oiling a K&N filter rather than replacing the OEM filter over and over.
Spot on Colin. The only other thing I would add to that, is that should you have a Lexus dealer carry out routine servicing, you will most likely find that your expensive K&N filter is changed during the vehicles routine service. They may even cite warranty issues associated with fitting non genuine Lexus components. So, depending on the age and mileage of your car, it could work out to be more expensive in the long run. If you service the vehicle yourself and it is already out of warranty ties, then this shouldn't be a problem.
