Hi all,
As you might have seen in a previous post, I wanted to modify the fog light switch on the stork so that it would operate the fog lights without having any other lights on first. I don't believe this can be done without going to a skilled auto electrician and paying their high labour rates.
Sticking with the idea of using LED headlight bulbs in the OEM fog housings to run as DRLs, I found these units sold by TRS to facilitate the auto on/off control for UK MOT regulations:
http://www.theretrofitsource.com/components/harnesses/morimoto-xchange-switchback-drivers.html#.Vg0rpPlVhBc
Have emailed TRS for fitting advice and they said there are 3 wires on the units requiring input from my car:
1) a 12v feed from ignition (to turn on lights when car is started)
2) a ground
3) a feed from the parking/side light circuit (to turn off power when sidelights are switched on - which is UK regulation for DRLs)
Each of the above is required twice (one for each side) so am I right to be nervous to take 2x live feeds from a given ignition source?
Should I add an inline fuse?
Where would you recommend I take the live feed from so that the lights only come on when the engine is running?
Any other helpful comments are welcomed.
Bill
