Afs Light On And Fluttering Noise From Dashboard
I am in in the process of sorting a number of niggles the last two are the most difficult to diagnose. I would be grateful if anybody who has had similar problems and could point me in the right direction
Rx 300 se satnav 2005
Many thanks
Try checking height control sensors attached to rear anti-roll bar behind the drop/stabiliser links, easy to see with rear wheel removed. There should be another much smaller drop/stabiliser link from the anti-roll bar that goes to the height sensor and not uncommon for them to seize or even snap.
I'll try and get some pics on Friday when I replace my rear strut, if you can't locate it!
