I have put together a couple of tips which I hope will prove usefull if you have a hybrid & are off on your Holidays.
First of all & most importantly disconnect your 12 Volt accessory Battery there then can be no possibility of an excessive drain on your hybrid Battery,
Some models may not have a manual key so if yours is one of those I would suggest securing the car in a locked garage first.
When you come back from Hols reconnect your accessory Battery securely remembering to observe correct polarity.
Operate each individual electric window by it's own switch on it's own door (make sure to take them all the way down & up this resets the cluster at the drivers door.
Once you have started the car turn the steering wheel full lock to each side a couple of times this helps to re centre the steering.
As I think of other tips I will post them - happy holidays you lucky people!
I don't know how long some peoples holidays are but I have left my car for just over two weeks parked up and she fired up just fine when I returned.
guys i posted in the technical forum but didnt get a reply so im asking again
im on the look out for a nice 06/07 or even 08 plate 450h and want to know is there any tell tale signs of hybrid cell failure.
Can the car be run on just the petrol engine in the event of a big expensive hybrid failure i.e inverter
and finally is it better to go for a low mileage (under 100k) or one which has slightly higher mileage albiet maybe motorway runs in which case the hybrid components will have less wear and tear therfore longer life
manyy thanks for your help
An inverter failure would shut down everything. No 12v supply, no power to start the engine (one of the electric motors turns over the engine), no reverse (reverse is electric only).
I leave my car in the garage for two or three weeks on a regular basis, without any problems. If yours is a problem, I would suggest it's time to change your 12v Battery. The Battery in my old BMW would discharge in two weeks. I changed it and found I could leave it for a month with no problems.
The post was meant to be of assistance to those with older hybrids & those out of warranty, as long as owners bare in mind what Colin pointed out about insurance.
I have plenty of experience in this field.
