Morning, can anyone recommend somewhere I can get a service and cam belt change on my ls430. I live near Romford in Essex. Thanks.
There are Lexus dealers giving out a good deal on the cambelt change incorporated with a full service make sure you get the water pump changed if it is a second belt change .
Thanks for the reply. It appears that woodford is my nearest lexus dealership. I'm not sure what level of service I need but I'll check with my service manual when I get home. As you have stated it is a 2nd belt change so the water pump change makes sense too.
