Cheers guys. Nice to know I am not on my own, or is it?  Actually I would prefer it if I had a dodgy seal and it wasn't inherent in IS design. I will ask them to look at that during its first service.
Mine does it, my neighbour's car too. Seems to be an inherit design issue with the seal. Lexus should produce a modified one.
Seems to be worse in colder weather which seems to suggest expansion in warmer weather closes up the gap.
i have been fiddling with the seal between the front and rear door
at the top of the front door where there is a hard corner i have attached some self adhesive felt
on the rear door on the front edge at the top the seal has a notch cut into it, across the notch
i have applied another piece of felt and i have to say it does sound less noisy,i am at the moment waiting
for a replacement plastic outer door panel with seal to arrive at lexus to see if it could be just due to the softening
of the rubber seal its £28 + vat so i dont mind giving it a try
Could have gone hard I guess.
Atleast its not as bad as *cough* BMW. The M135i and the 3 series my colleagues have got keep smearing the glass whenever they roll the windows down. I took a look and the seals are like rock hard!
Back on topic - no noise in the IS - its still dead quiet and rattle free. Only done 11k miles but its still 2 years old lol.
the part has turned up today just waiting for the weather to become dry as the panel is held on
with 1 small press clip and double sided sticky tape (they must have blue peter in japan also)
  • 1 month later...
Bad Discovery - I find the heated seats don't get hot enough for me personally.
Good Discovery - The cooling function on the seats is ice cold and great for after the gym!
That one is quite a regular complaint unfortunately.
Although watch out as the temperature has three settings and will slowly decrease after a certain amount of time. You can reset it by pressing the button again.
The seats can be set not to decrease. I don't understand why they are so pathetic,  last week I had a ct loan car and had to turn the seats down,  they were so hot.
I don't know how true it is but I have heard somewhere that Lexus and Toyota lowered the seat heating temperature in all their models because
of concerns, particularly in the Far East, that overheated seats could pose a health risk in very young children and pregnant women.
I have to have my seats on the lowest setting or I get Griddled. I must just have a naturally warm bottom (steady with the comments) :P
David
Thank you, I will switch the seats to stay on permanently to see if that makes a difference.
They heat up fine. Same in my RX. Bloody hell though the new RX heaters are another level though
10 hours ago, PaulWhitt20 said:
I hardly ever use the heated seats. I wear a coat.
You do know that there is a heater in the IS & CT ?  :tongue:
Yes but I think my Climate Control is playing up. I keep pressing the snow button but it never starts to snow.
  • Like 4
You are obviously not au fait with all of the cars technical abilities, you can press the snow button as often as you like but it won't snow, the car is clever enough to know that you aint got winter tyres fitted and so therefore won't put your safety at risk!!!:yahoo:
  • Like 4
Interesting discovery last night, Lexus IS cup holders are a perfect fit for a standard bottle of wine! :wink3:
.... and a tin of baked beans!
Wiper can be set between auto and manual mode, car has to be stopped with wiper off and long press on wiper side button and the green light on stalk will blink a few times.  When it is just drizzle and car is moving slow auto mode just won't get wiper working even in highest sensitivity setting.
My Advance model does not fold the door mirrors in when the car is locked. Has anyone been successful in getting this programmed into their car.
i have seen kits on eBay to add this function
http://www.ebay.co.uk/itm/Car-Auto-Side-Rear-View-Rearview-Mirror-Folding-System-Closer-Kit-Intelligent-/141660988371?hash=item20fba723d3:g:3G0AAOSwoBtW6RL1
I found out about these from another forum I am on.
if you search eBay there are sellers doing kits for Toyota's so having a kit for a lexus I am sure is possible.
Richard, if your car does have this function it is activated when you press the 'Auto' button opposite your mirror fold button.
This has to be lit. It's a little annoying as every time you manually fold the mirror, you have to remember to set it back to 'Auto'.
Hope this helps.
Lee.
I think I missed something here, Jimmy, sorry!
This morning, with the wipers on Auto setting, I just flicked the stalk upwards for a single sweep, and the auto setting wasn't affected.
With car stopped have you pressed the button to get the green LED blinking a few times to get to manual mode?  Make sure car is stopped. After setting manual mode you flick the stalk downward once for intermittent manual mode and use the dial to adjust frequency.  It's all in the user manual.
Hope this helps.
Lee.
I've to fold mirrors before parking next to wall so if mirrors unfold automatically when car is unlocked they would hit the wall so it makes sense to manually unfold them in this situation.
