Under the Rx section of this community Forbesy has posted a fix for his Rx300 Sel ride height sensor.
He shows photos of the sensor taken apart and how to test the resistance for correct operation.
If these £300 sensors are essentially the same for the air suspension LS series then his contribution is very interesting.
I spray the exterior of mine with ACF-50 Corrosion Block in the hope of keeping water out.
