Frnt Heater Screen Button.
Guys,
Does anyone know how I can check that this works as it should, been looking through some threads on this and I am not sure I have had this fitted when I had a replacement window fitted a year ago? The button lights up but the revs don't move and I cant find any inkling of heat coming from the window.
I have to admit I never even used this before I had the window out, just gauging how I can tell if its actually working, or not!
The side mirrors heat up as they should.
Guys,
If you have it on your windscreen it will be quite obvious when you look at the glass. The heater element only covers the bottom few inches but it's none the less easy to see.
If your glass is clear then you don't have it.
Carl
