Gs Timing Belt
jimb
I'm new to this forum....
I'm in the process of buying a '98 GS 300 which is close to needing a 60,000 mile timing belt change...just wondering what dealers charge for doing this ... or is it a job i could undertake myself!
I paid a lot for the same job on my previous car - a '98 LS400 - but the job was done abroad as I did not live in England at the time.
Cheers
  • 2 months later...
my friend and I have just finished replacing the cambelt on his GS300 SPORT 99
model
the hardest part was undoing the bottom pulley bolt, the rest was quite easy.
we had been quoted by two dealers one said £297 the other said £320.
the belt itself is only £44.00.
john
  • 2 months later...
With the other things required on the 63,000 miles service
What are the other things that need doing?
My Dad's is due the 120,000 service and he wonders what needs changing in addition to the cam belt and spark plugs because he'd like to have a go himself?
Also he said there are two spark plugs you can't get at (or easily) and was wondering how you do so?
Brake fluid should be changed every 2 year/20,000 miles, engine coolant should be changed every 2-3 years so it depends when those two things were last done.
Everything should be listing in the service book.
The intake and throttle body go across the top of the engine and this has to be removed to get to some of the plugs.
  • 5 months later...
