I have a '97 LS400 with the standard entertainment system (radio/multichanger cd/cassette).
The backlighting doesn't work. It seems to be a common fault, judging from internet aricles I have read.
Can someone advise what the fix is (new bulb(s)?). If it is new bulbs, where can I get them, and how do I remove the front fascia of the unit so I can fit it/them? Some of the stuff I've read suggests that some soldering may be required. I'm OK with doing that, but just need some advice.
Thanks in anticipation
if you get stuck i paid someone else to do it for me - i used car audio repairs in hove - they charges £85 inc delivery back
If your OK with soldering I would suggest getting hold of some liquid flux ( RS components or CPC ) before you attempt the resoldering as the resistors are surface mounted not through wire.
If your not confident I can do these repairs so feel free to PM me.
You should also find that none of the other illuminated centre console buttons light up with this problem.
