Starter repair kit arrived today.
I can't back out anymore now, can I? :)
Really not looking forward to this job with LPG fitted :(
post-26221-0-93161700-1441719450_thumb.j
do plenty of "pre-op" reading
take plenty of coffee breaks (not beer lol)
a clever tip from steve is once you have replaced the starter solenoid - put it on a Battery to see it engages
there are some clear pictures here which might help
http://www.lextreme.com/forums/showthread.php?t=11862
all the best - the most i have done on my 400 is change the brake pads so my hat goes off to you
Good luck with that, don't forget to have plenty of tea, coffee and biscuits on the go together with a comfy chair to work out the problems in a professional manner. Mike.
Little gas pressure forward of the front solenoid I imagine, but shut off the tank tap as precaution.
Would be interested to see how they placed the spuds on your manifold. Are you taking pictures as you go?
good luck you are a braver man than I Gunga Din, as the expression goes!
If this job is on a 400 and you are taking the motor off, when the starter bolts are removed, clean the threads perfectly.
Then cut a good screwdriver slot in the threaded end.
When refitting, use a screwdriver to 'wind them back in' as far as you can, then finish with a spanner as usual.
As you can only get little more than a quarter turn on them with a spanner, this will speed up assembly, it works.... I dId it on mine!
@ Stuart - Yes I will be taking pics. I will need help where everything goes when re-assembling :)
@ Roy - Cheers for the tip. And yes, it's on my 1999 Celsior.
Maybe I don't need to do this anymore...
Put a new Battery in today and voila...no more click click :)
Probably a good chance it is a weak Battery problem.
Just had the same symptoms (click, click) on my wife's car, replaced the Battery and the engine starts fine now with no click, click.
Let's hope that's what it is, so you do not have to replace the starter motor.
About 2 weeks after I did my starter I remember having the exact same symptoms with the click click, turned out I hadn't quite tightened one of the Battery terminals fully.
Never had a problem since.
One good thing about the Celsior is there is no EGR system to worry about and having to remove with that fiddly pipe at the rear of the engine.
Started her up a few times today as well and still no click-click.
I really hope it was the Battery. I honestly don't care that I spent £13.50 on a repair kit I might not need :)
I thought that mine was a duff Battery as the problem disappeared when new Battery fitted - for 2 weeks. I got it fixed at a friend's garage - wasn't too expensive at about £120 if I recall.
Pete
I really hope it was the battery. I honestly don't care that I spent £13.50 on a repair kit I might not need :)
I carry one around in the boot just in case I get caught out abroad.- also replacement Serpentine Belt.
Good idea. I will add it to my boot supplies :)
Even now, two weeks later, no 'click click' Still fires up at the first turn :)
