Hi ruud I know it's an old post on the if change you are still around I'm having exact same problem as you woth a 1992 celsior satnav climate control all not working.. did you just locate a non sat nav climate control from same year car and put in your own double din was the climate control plug and play 👌
Dan hi, Ruud was last on here in May 2017
Steve2006 is a more recent Celsior man with older Ls400 skills set and loadsa knowledge …… he might be able to help !
Good luck
