Hello Guys,
I have got 2007 reg is 250. I have got problem with my audio system. In the morning both cd player and radio was working fine. But in the evening when i was returning from my office both cd player and radio stopped working. I am not able to change cd and not able to eject cd as well.
I can listen to songs from Iphone via AUX and also i can take calls from phone as well via Bluetooth.
I checked in the boot and all the connections were fine from amp.
I also checked radio fuse from main head unit and inside driver panel. All the fuse looks fine.
I dont know what happend.
This thing once happenned in the past but it got solved when i restarted the car.
Any advice will be much appreciated.
Regards
Hi Avi and welcome to the LOC, we are a
friendly bunch and some of us even know how to pull them to bits and
put them back together again, with of course the one bolt and washer
left over. Regards Mike.
Thank you Mike, really looking forward for some solution of my problem :)
Perhaps try pulling out the radio fuse.leave it for a while then put it back in ( if the radio is coded make sure you have the code!)
Nothing changed :(
Have moved this to the IS250 forum where you will hopefully get more response. Mike.
