Hi all I've just had my is220d in the garage as the vcs light came on was told dpf was worn out been told New one has been fitted just picked it up and now getting white smoke after a few miles is this normal? Thanks
Its only build up of condensation in the exhaust pipe, all cars do it, good sign your engine is in fine
fettle. Mike
Any other symptoms,loss of power for example?
I would give it a few days and see what happens,if still the same I would then revisit the garage that did the work.
Thanks just took it for a blast on the motorway all cleared up thanks for replies
