Fluid Change Automatic Box
Pointer772001
Hi Everyone,
I have a 2003 IS200 with the automatic gearbox and I have always known toyota/lexus autos to be very smooth.
Mine is smooth but shifting from 1st to 2nd is becoming slightly jerky (2nd to 3rd and 3rd to 4th I cant even tell when it changes)
Is it just because its a low gear that it will be a bit jerky or does it need a fluid change?
I would have this checked out at a garage, the simplest thing you could do it change the transmission fluid and see if this fixes it?
I had a manual (from another manufacturer) and the 1st/2nd gear changes were clunky, i had the transmission oil changed and it fixed that issue for me. I'm not saying this will fix yours because yours is an auto so could be other factors.
