Hi Everyone,
I don't know if anyone can help but my passenger side folding mirror has decided to not fold in when pressing the button.
The drivers side folds fine and I can still adjust the passenger side mirror glass as well, it just wont fold (although manually it does)
I have checked fuses but I assume they're fine because the other mirror works unless they have separate fuses?
Thanks!
Hi try spraying some WD40 behind the glass this will hopefully get rid of the dirt that has built up over the years(assuming that the motor hasn't packed up) and should get it working again
Hi Scudney
That's done the trick, sprayed it this morning and it folded :) thank you.
Funny what a bit of oil can do... unless it miraculously fixed itself overnight!
Thanks again
